Home » Audio » Thermionic Emissions » Say Douglas
Say Douglas [message #9286] Sun, 16 October 2005 07:11 Go to previous message
This newsletter; will that be available to anyone who is interested?
I have some ideas about presentation if you want to hear them.
From the standpoint of a semi-novice there are some issues that would provide a great help in getting started on simple design/build issues that I would like to see.
As an example of what I mean I think the first issue should be the Amp/Pre-amp interface as well as the source/pre-amp interface.
Thats the kind of stuff I find to be very helpfull in understanding the whole picture.
Then the why's of transformer explained as a set of steps regarding electronic parameters and personal choices of same.
Is that something along the lines of what you had in mind or is that too basic?
Leave each lecture with a question that must be solved by the attendees or readers; then explain at the next lecture the how and why of the solution. I find that sort of interactive learning to be good.
There's more if you are interested. Thanks for listening.
Previous Topic: Need 15 watt plus SET design for DIY?
Next Topic: out of my way Flanders! I've got a class to teach!
Current Time: Sun Nov 22 22:55:25 CST 2026
