Re: 4pi flat pack, Rhino Line [message #92292 is a reply to message #92257] Wed, 09 September 2020 13:53 Go to previous messageGo to previous message
So the little teeth on the Tee Nut are obviously meant to penetrate the substrate - MDF in this case. If you hammer them in, the teeth get bent and mangled and usually cause more harm than good and also put the Tee Nut in crooked which can lead to cross-threaded bolts. That is a nightmare!
So using those grade 5 bolts and washers you "draw" the Tee Nut up into the substrate. DO NOT tighten too tight, just enough to squeeze the extra PL out and hold it. Remember: The PL is really what is holding the Tee Nut, not those goofy teeth. I personally like to leave the bolts in for 48 hrs to make absolute certain the PL has fully cured.
/forum/index.php?t=getfile&id=2626&private=0
Previous Topic: Pi 8 plans
Current Time: Sat Nov 14 13:54:27 CST 2026
