Home » Audio » Thermionic Emissions » $ v. :-)
Re: mmmmmhhhh.... [message #9229 is a reply to message #9228] Mon, 03 October 2005 06:26 Go to previous messageGo to previous message
I see your point and I did answer the wrong question. Building as cheap as possible then designing around the shortcomings? Interesting concept. As cheaply as possible would probably get you a decent sounding amp; right? So are you suggesting that this be a way to upgrade that would allow people a low initial entry fee; or is it a way to find out what the possibilities are?
My question is regarding the cost of building it is all in the Transformers and chassis with a little in caps if you use real expensive ones so where would you save except in using dirt cheap tubes?
Previous Topic: Low gain linestage
Next Topic: Yamamoto A08 tweak
Current Time: Tue Nov 03 03:52:16 CST 2026
