Re: 4pi flat pack, Rhino Line [message #92287 is a reply to message #92257] Wed, 09 September 2020 13:49 Go to previous messageGo to previous message
Next was some sanding. I chose to use an orbital sander with 80 grit to knock the overhang of the baffle off and really get the MDF smooth. As my previous painting training has taught me the prep work is the dirtiest and certainly the most important for the final finish. I used BIN Primer that I had tinted as a white base with black Duratex going over didn't make any sense to me. I did one coat of BIN then sanded with 120 grit and repeated.
/forum/index.php?t=getfile&id=2619&private=0
  • Attachment: IMG_3515.JPG
    (Size: 2.90MB, Downloaded 1416 times)
Previous Topic: Pi 8 plans
Current Time: Sat Nov 14 13:54:31 CST 2026
