Home » Sponsored » Pi Speakers » Horn loaded Corona Build
Re: Horn loaded Corona Build [message #91914 is a reply to message #91874] Tue, 19 May 2020 15:43 Go to previous messageGo to previous message
dawiipgh is currently offline  dawiipgh
I have a question based on interchanging components.
If I start the build with the base model components (Eminence) and later upgrade to the higher end components (JBL and B&C), will the existing cabinet and crossovers still work?
  • Will the screw holes for the woofer and mounting location for the compression driver be the same?
  • Are the resistors and capacitors the same on the crossover board?
  • And most importantly, will I be able to install the needed upgrades through the existing openings for the woofer and waveguide?
If anyone has gone through an upgrade, I'd love to hear about it!
Thanks,
dawiipgh
Previous Topic: 7 Pi plans
Next Topic: Subwoofer amp and crossover
Current Time: Fri Sep 25 19:15:44 CDT 2026
