Home » Sponsored » Pi Speakers » Horn loaded Corona Build
Re: Horn loaded Corona Build [message #91902 is a reply to message #91888] Mon, 18 May 2020 07:41 Go to previous messageGo to previous message
dawiipgh is currently offline  dawiipgh
Thanks for the guidance, I have come across some great builds. You lot are a talented bunch.
Are there any components that require to be mounted prior to finishing the cabinet? For instance, does the compression driver driver need to be mounted before the front face of the cabinet is glued in place. I am working on the cabinet build first and then will purchase the drivers, waveguide, crossovers, wiring etc.
The cabinet looks large enough to easily install all of the components in a completed box.
Thanks again.
dawiipgh
Previous Topic: 7 Pi plans
Next Topic: Subwoofer amp and crossover
Current Time: Sat Sep 26 01:18:55 CDT 2026
