Home » Sponsored » Pi Speakers » Horn loaded Corona Build
Re: Horn loaded Corona Build [message #91887 is a reply to message #91886] Sat, 16 May 2020 14:10 Go to previous messageGo to previous message
Your baffle will have a cutout for the woofer, so there's your access for wiring. There's all kinds of images on the web for doing bracing. Some of it so intricate and precise is seems a shame to close it all up inside the box. Then, there's simple 2x4 placement. Your horn lens and driver just screws into the baffle. Many double up the thickness of the front baffle and flush mount the woofer and horn lens to the outer surface of the baffle. And use t-nuts or hurricane nuts mounted inside the baffle screw holes to accept heavy duty hex screws.
https://www.parts-express.com/cat/nuts-t-nuts/313
Here's a build post. Not the 4 pi but showing some images of bracing.
https://audioroundtable.com/forum/index.php?t=msg&goto=88075&&srch=4+pi+build+pictures#msg_88075
Previous Topic: 7 Pi plans
Next Topic: Subwoofer amp and crossover
Current Time: Fri Sep 25 21:10:23 CDT 2026
