Home » Audio » Source » Bent records
Re: Bent records [message #91848 is a reply to message #91847] Fri, 08 May 2020 08:10 Go to previous messageGo to previous message
Wait a minute. The vinyl record is made with heat and pressure. Looking it up shows it to be, 345 F and 100 tons of pressure. So, I don't think the freezer will cure the warp. All it takes is a little search here. Pre heat your oven to 150 F, put your clean record between two clean panes of glass. Pop it in the oven for 10 minutes. Taker er out and set aside to cool with some weight atop the panes of glass. I might give it a go.
https://www.youtube.com/watch?time_continue=342&v=IwHZZe3aOh0&feature=emb_logo
Previous Topic: Create your own
Next Topic: Clear Vinyl
Current Time: Tue Nov 17 13:19:04 CST 2026
