Home » Audio » Thermionic Emissions » Fisher 500C-how hot is too hot?
Re: Fisher 500C-how hot is too hot? [message #9182 is a reply to message #9179] Mon, 05 September 2005 09:45 Go to previous messageGo to previous message
The series resistor for the bias voltage has been completely by-passed a long time ago. There just isn't enough voltage there to reach 26 volts without changing the 15 ohm resistor to ground. The way it is currently hooked up with the 2 ohm resistor replacing the 15 ohm, I am getting:
Plate= 440 VDC
Screen= 300 VDC
Grid= -24 VDC
Also, some time ago I replaced the 1.2 ohm resistor between first and second stage in the high voltage supply with a 7.2 ohm. This is what lowered the screen voltage.
It gets complicated, but it does seem to play well and sounds wonderful. The things I'll do to save money. EL34's are still cheaper than 7591's. Besides, I love the sound of EL34's.
Dave
Previous Topic: One output transformer hotter than the other
Next Topic: DRD 45's in gear.
Current Time: Thu Sep 24 00:03:15 CDT 2026
