Home » Audio » General » Behringer DEQ2496
Re: Behringer DEQ2496 [message #91572 is a reply to message #91570] Tue, 17 March 2020 16:03 Go to previous messageGo to previous message
What are you going to use it for? If you are going to use many amps and individually drive woofers and tweeters with separate amps it might be just the thing.
I had a similar device, a Driverack PA, that was bought to do room correction. Ultimately it was abandoned as it only helped a bit at the sweet spot but seemed to make the rest of the room sound worse. It also seemed to remove some of the beauty of the tube gear in the system.
A far better solution turned out to be multiple subs. They did more to make the room listenable than the EQ and they do their magic throughout most of the room.
The Behringer may or may not be the answer. Just depends on the question.
Previous Topic: Interesting facts about sound
Next Topic: Wanting Better Sound
Current Time: Wed Nov 18 10:58:16 CST 2026
