Home » Sponsored » Pi Speakers » Low Pass
Re: Low Pass [message #91410 is a reply to message #91407] Mon, 03 February 2020 18:23 Go to previous messageGo to previous message
Hi Rusty,
Don't blame you for not doing work in the winter cold. Both the winter cold and summer heat are great ways to kill motivation.
Yes, the Amp Camp Amp is an 8 watt class A amp and it's being used as the main amplifier for the system. The REL sub has a built in plate amp that connects to the outputs of the main amp rather than using the outputs from the preamp. The REL is in the rear of the room.
The front subs are driven by the preamp (preamp --> Driverack --> volume control --> class d amp). It's set to a 12db slope but the frequency gets varied a bit ... still trying to figure out which frequency works best. The 4's are not pulled out from the walls on stands as Wayne suggests, they are on the floor next to the wall so they don't quite need the standard flanking sub settings. Again, still playing with the settings as it's only been about a week.
Eventually the 4's will go on milk crates and get pulled from the wall when somebody is around to help me lift them. Then we go full flanking sub. Smile
It's easy to live with the system as it is right now so there's no real rush.
Previous Topic: 2 Pi Speaker Plans
Next Topic: Corner horns & flanking subs?
Current Time: Sun Nov 15 09:04:12 CST 2026
