Home » Sponsored » Pi Speakers » Needing Some Mid Horn Hints
Re: Needing Some Mid Horn Hints [message #91393 is a reply to message #91392] Thu, 30 January 2020 18:51 Go to previous message
The mounting plate is smaller then the enclosure so you can have access to both sides of the mounting plate and also to the area surrounding the flare. I usually fill the area between the flare sides and the cabinet with acoustic insulation. I also like having some wedge-shaped braces between the side panels of the horn and the cabinet.
Previous Topic: 3pi plan request
Next Topic: Thermionic 3 question
Current Time: Fri Nov 20 02:29:02 CST 2026
