Home » Audio » Thermionic Emissions » Super simple linestage.
Super simple linestage. [message #9136] Sun, 31 July 2005 17:35 Go to previous message
Thrint is currently offline  Thrint
For those who don't need any additional gain I ahve an idea. It is even all SS, though the development model is completely valve.
One needs a high gm, low input capacitance device to act like a cathode follower. Some pentodes work quite well, but a pair of DN2540 mosfets rigged in cascode as in the Guinevere plate loads is even better. No set resistor is needed.
Have this device ride on a goooood CCS. Again the Guinevere plate loads will do well, and this time we *WILL* build the complete thing. Set it to sink 10 mA.
Attach the volum pot's wiper to the lower gate, and cap couple from its source( as in Guinevere ).
Supply a +/- 60V set of rails and we're off...low output Z, wideband response, and no silly high voltage capacitors needed.
For parts, a 120V CT power TX, two 10 Hy/100 mA chokes and two good capacitors are all that's required. Figure $100 max if you don't want a gold-plated box...
regards,
Douglas
Previous Topic: Chicago Audiofest Website
Next Topic: SET amps that will only rock Septeguenarians
Current Time: Sat Oct 17 13:03:38 CDT 2026
