Home » Sponsored » Pi Speakers » 3 Pi sub questions
Re: 3 Pi sub questions [message #91306 is a reply to message #91304] Mon, 06 January 2020 08:59 Go to previous messageGo to previous message
The three Pi sub kit is really just a woofer and port material. We also include the connector panel, a "π" logo and a printed copy of the plans. There is no passive crossover included.
The crossover, as you've rightly indicated, is specific to the application. Flanking subs use a different crossover than distributed multisubs. And those are different than a traditional single sub application, which I do not recommend, by the way.
There are many suitable crossovers and amps you can use. The simplest would be to mount a plate amp to the back of the box. But most plate amps have limited crossover options. You can also use a separate amp with MiniDSP, which would allow you a great deal of flexibility for crossover filters. Flanking subs use a 100Hz second-order Butterworth filter, which is a one-click setting in MiniDSP. Distributed multisubs can usually be run from the LFE channel.
More about multisubs and flanking subs at the link below:
Previous Topic: PI 2
Next Topic: Constant directivity cornerhorn plan request
Current Time: Thu Nov 26 19:13:35 CST 2026
