Home » Sponsored » Pi Speakers » 4PI Plans Request
Re: 4PI Plans Request [message #91245 is a reply to message #91244] Mon, 09 December 2019 12:25 Go to previous messageGo to previous message
I think that's a good way to go. Run the flanking subs with a 100Hz/2nd-order low-passed copy of the signal sent to the main speaker each sub is flanking. Run the mains set to "large" so you blend with the flanking subs. The mains should be able to handle the LF content unless they just really can't handle the low notes or you are pushing them close to their limits. If you're pushing them hard, then high-pass them at their Helmholtz frequency.
This Helmholtz recommendation is, of course, relevant for vented systems. Above the Helmholtz frequency the vent reduces excursion, but below Helmholtz the woofer is unloaded. If sealed, it's not such a stark a change in excursion but then again, there is no reduction of excursion from the vent. So for sealed woofers, high-pass where excursion becomes a problem either because of IMD or xmax or both. The goal is to run the mains as low as possible for modal smoothing.
The improvements from flanking subs and multisubs are measurable and audible. The effect is anywhere from subtle to striking, but it's always noticeable. Flanking subs make the upper midbass and lower midrange smoother. Male voices, piano, guitar and cello sound clearer. Distributed multisubs make the deep bass smoother. You will notice bass notes that seemed light or even missing before. Sounds like a better foundation.
Previous Topic: Flanking subs
Next Topic: For Sale: 4 Pi speakers (upgraded drivers) + pair of 3pi flanking subs
Current Time: Thu Sep 24 13:15:58 CDT 2026
