Home » Sponsored » Pi Speakers » 4PI cabinet drawing (A copy, please)
Re: 4PI cabinet drawing [message #91228 is a reply to message #91226] Wed, 27 November 2019 15:44 Go to previous messageGo to previous message
You've got mail!
Be careful with plywood though. The only product I can endorse is Baltic Birch. It is made with very thin laminates clamped under a lot of pressure and held with plenty of glue. This fills any voids present in the laminates with glue.
The problem with most plywoods is internal voids. Debris in the voids can buzz. And even if a sheet seems to be free of buzzes at first, it often times has voids that shed debris over time. So a panel develops a buzz after a few months or years. The vibrations from the speaker tend to shake loose debris, that then buzzes in the void.
Previous Topic: MiniDSP
Next Topic: 3Pi Acoustic Axis and Listening Distance
Current Time: Sat Oct 31 04:10:41 CDT 2026
