Home » Sponsored » Pi Speakers » Three Pi and Three Pi Sub Plans (Plan Request)
Re: Three Pi and Three Pi Sub Plans [message #91222 is a reply to message #91221] Sun, 24 November 2019 16:47 Go to previous messageGo to previous message
Glad you got the mains done! I'm sorry you're having trouble with the tweeter circuit though. Do check your connections - The treble SPL should be equal to the bass SPL. Without R1/R2 attenuation/compensation, the tweeter would be 10dB higher than the midwoofer, so something is amiss. Could be that you've effectively shorted R1 in some way.
The sub kits have port material included, so wait until they arrive and cut the port hole to match the duct material. The hole diameter shown in the plans is accurate, but having the duct in your hand might help you get it exactly right.
Previous Topic: New Four Pi completed
Next Topic: Please help ID of 2 sets of speakers
Current Time: Thu Nov 12 20:39:25 CST 2026
