Home » Sponsored » Pi Speakers » Low Pass
Re: Low Pass [message #91186 is a reply to message #91181] Sun, 17 November 2019 17:58 Go to previous messageGo to previous message
One trick I read about and have used for guitar cables is to used balanced cable (microphone wire with two conductors + shield). The trick is to only connect the shield at one end, ideally the end with the best ground. This way, the any noise would get grounded and the signal would be cleaner. Not balanced cleaner, but better than carrying the signal on the shield, which is where the noise would be induced.
Chris
Previous Topic: 2 Pi Speaker Plans
Next Topic: Corner horns & flanking subs?
Current Time: Sun Nov 15 09:03:56 CST 2026
