Home » Sponsored » Pi Speakers » Just finished 4pi build need some tips
Re: Just finished 4pi build need some tips [message #91082 is a reply to message #91069] Mon, 14 October 2019 10:13 Go to previous message
Very good. Glad to hear you got 'em together and they're sounding good.
The placement and orientation you have described is good. They might stand to be a little bit higher, but they're pretty good where they sit. I usually put mine on 15" stands, but again, there's not much difference so what you've got probably works very well.
I would encourage you to employ flanking subs. It will improve the lower midrange as well as provide deeper bass extension.
Previous Topic: 8 Pi Plans
Next Topic: MiniDSP
Current Time: Fri Oct 30 13:02:23 CDT 2026
