Home » Sponsored » Pi Speakers » Definimax 4012HO - End of Life
Re: Definimax 4012HO - End of Life [message #91040 is a reply to message #91036] Mon, 07 October 2019 09:07 Go to previous messageGo to previous message
Mabob wrote on Mon, 07 October 2019 08:01
I´m about to pull the trigger on Delta Pros. Still a bit unsure if these will give me a significant update compared to the 12LFA? I feel that there's quite a bit low end output and kick missing.
Do not forget that this design almost requires flanking subs for deep bass response. You can consider it to be a three-way design with the woofers detached.
They are adequate without subs, but certainly not optimal. They get better bass extension and even smoother lower midrange response by adding flanking subs. This approach provides baffle step compensation and SBIR/modal smoothing in addition to deep bass extension.
So while you can use the three π or four π speakers without flanking subs, they are designed to be used with them.
Previous Topic: Where to get JBL 2226 Dustcap Replaced?
Next Topic: Time to build 2 pi towers?
Current Time: Wed Sep 16 21:35:40 CDT 2026
