Home » Audio » Source » R2R ladder dac's
Re: R2R ladder dac's [message #91018 is a reply to message #91017] Thu, 03 October 2019 12:33 Go to previous message
You're right that the key to quality is precisely matching resistor values. It's kind of like tube matching. You just get a ton of 'em and measure to find exact matches. The resistors are cheap, so that's not a problem. It's the time it takes to do it that might be kind of a drag.
That little board would be great for an 8-bitter. But I think I'd prefer more resolution that that. Look for something like this:
You could go to a higher resolution than 16-bits, but I'm not sure you would benefit from it 'cause the minute differences of resistor values would probably be greater than the increased resolution you gained.
Previous Topic: Uncompressed audio formats
Next Topic: USB compatible turntable
Current Time: Mon Oct 19 16:27:35 CDT 2026
