Home » Audio » Source » R2R ladder dac's
Re: R2R ladder dac's [message #90940 is a reply to message #90938] Thu, 26 September 2019 11:08 Go to previous messageGo to previous message
Resistor-ladder DACs were the very first kind. You can actually make one with a parallel port and a series of precision fixed resistors configured as voltage dividers. Each bit has its own resistor, all tied together. Just send the digital stream to the serial port and the resistors sum to create a voltage output.
So the key really is to have very precise resistor values. Nothing else about it is tricky or expensive. You could even buy a bunch of inexpensive resistors and measure them yourself to hand-pick the exact values, sort of like tube matching.
Previous Topic: Uncompressed audio formats
Next Topic: USB compatible turntable
Current Time: Mon Oct 19 16:27:18 CDT 2026
