Home » Sponsored » Pi Speakers » Definimax 4012HO - End of Life
Re: Definimax 4012HO - End of Life [message #90841 is a reply to message #90830] Fri, 06 September 2019 22:16 Go to previous messageGo to previous message
Symphonimind is currently offline  Symphonimind
Mudshark wrote on Thu, 05 September 2019 08:24
@ Symphonimind:
I'm using the B&C DE250 (£83 (€91) ea in the UK including VAT ($83 without tax). I always knew I'd want to upgrade the compression driver so I went straight for the top option. The PSD2002 is £62 here so not much of a price difference in the context of a €800 build.
I found the top end to be a little laid back with the default xover options so I'm using 22R/15R for R1/R2 (C1 omitted) which adds a bit more sparkle and gives a flat response through the xover region with a slight rising response starting at 10 kHz which I can't hear anyway as my hearing pretty much stops at 11 kHz.
I found that the H290C waveguide rings like a bell when you hold it by the flange and rap it with your knuckle so I damped the two larger sides with triangles of 5mm Dedshete and it's now completely inert, so that's my DE250 setup.
Thank you a lot. I will try to damp my existing 3Pi (De250+4012HO) to see if it can make the mid and high smoother.
Edward.
Previous Topic: Where to get JBL 2226 Dustcap Replaced?
Next Topic: Time to build 2 pi towers?
Current Time: Wed Oct 14 10:28:26 CDT 2026
