Home » Audio » Thermionic Emissions » Fixed/cathode bias and AC
Fixed/cathode bias and AC [message #9083] Tue, 19 July 2005 09:44 Go to previous message
Thanks all for doing a great job in explaining this.
So fixed bias is derived from a voltage divider and a cap on the input AC signal. It has the advantage of allowing the tube to be operated at a fixed Vg.
Self-bias uses a resistor to react to changes in the signal by following Ohm's law and causing a plate voltage drop to change with the Vg.
The self-bias is self regulating and must operate in class A. It is easier to design due to the self-regulating properties of the circuit.
AC component on the plate voltage is removed by the by-pass cap.
Now why would anyone go to the trouble of using grid leak bias when they could just use the cathode bias? It seems so simple.
Previous Topic: bass preamp and 6418 pentode
Next Topic: Tweaker mono amp stage two pictures
Current Time: Sat Nov 28 20:05:58 CST 2026
