Home » Audio » Pro Sound » Adjustments for mouth-breathers and whisperers
Re: Adjustments for mouth-breathers and whisperers [message #90825 is a reply to message #90819] Wed, 04 September 2019 13:46 Go to previous messageGo to previous message
musicluvr is currently offline  musicluvr
Switch from a headset mic to a handheld mic and teach the mouth-breather to speak off axis so the heavy breathing won't be as noticeable. That will also keep some of the moisture off the mic. Could you be hearing plosive sounds rather than breathing? This can be fixed with a pop filter and you can attach it to the mic stand. As for your whisperer, well, maybe after practicing a few times the child will feel more confident and will speak up.
Previous Topic: Harman's How to Listen
Next Topic: Do you need any special skills to equalize sound?
Current Time: Fri Oct 30 16:24:20 CDT 2026
