Home » Audio » Thermionic Emissions » Fixed Bias v. Cathode Bias
Re: Fixed Bias v. Cathode Bias [message #9070 is a reply to message #9066] Sun, 17 July 2005 16:08 Go to previous messageGo to previous message
OK, first, off how are you running your el84’s. As pentodes with a screen supply, ultralinear, or triode connected.
The output transformer (+speaker) is the load and for modeling, is the plate resistor and they are fixed.
So, the Z-out is determined by the tubes dynamic plate resistance. If you add a unbypassed cathode resistor the DPR increases. For a triode it is Rk(u+1) "cathode resister x mue(amp factor) + 1. This is the effect of degenerative feedback.
For a pentode, I don’t know ask someone else.;)
Now if you bypass the cathode resistor with a big cap. From a AC (impedance) point of view it’s not there. So you are more or less back were you started, from a Z-out point of view.
So is any of this to worry about. No. there is not much you can change, so go with what you like and don’t worry…John
Previous Topic: I'm willing to reveal this about the Kit One:
Next Topic: Promise not to tell?
Current Time: Sat Nov 28 19:41:44 CST 2026
