Home » Audio » Home Theater » Power Surges
Re: Power Surges [message #90667 is a reply to message #90664] Wed, 10 July 2019 21:45 Go to previous messageGo to previous message
Hi An interesting issue. I use a power conditioner that will compensate for over and under voltages, spikes and EMI. The problem with many UPS is when the actually activate. The waveform many produce is not a clean sine wave. Often it is a stepped square wave. Some sensitive electronics might not be tolerant of it. Computers are designed to handle it (usually) so it is not an issue. I would personally use at lease a surge protector and prefer a power conditioner. I use an APC H15 series that is good for 15 amps. They show up used from time to time pretty cheap. If you go that way be sure that the seller will take it back if it is defective. They do fail from time to time (esp the H10s) and are too expensive to fix.
Previous Topic: Combining New With Old?
Next Topic: Suspended projectors
Current Time: Sat Nov 07 21:12:33 CST 2026
