Home » Audio » Thermionic Emissions » Mylar cap polarity - Help
Re: Mylar cap polarity - Help [message #9056 is a reply to message #9052] Thu, 30 June 2005 14:09 Go to previous messageGo to previous message
Audience (Auricap) recommends connecting the outer plate as signal input to the capacitor, probably under the assumption that output impedance of a prior stage is lower than input impedance of the stage following. But I like your suggestion that outer plate goes to lowest impedance, regardless of signal direction. If you know which is the outer foil, it makes sense to tie it to the lower impedance connection, where it will act more as a shield.
Previous Topic: Ned Carlson's new job!
Next Topic: needing to find a reliable source for tubes
Current Time: Sat Oct 31 04:10:36 CDT 2026
