Home » Audio » Speaker » Pi speaker arrangement.
Re: Pi speaker arrangement. [message #90401 is a reply to message #90044] Wed, 05 June 2019 19:20 Go to previous messageGo to previous message
Thanks Wayne.
I've made a bit more progress on the mid horns.
I chose to router a 1/4" deep groove out of the mounting plate, to compensate for the woofers maximum excursion, instead of using the spacer.
/forum/index.php?t=getfile&id=2368&private=0
I also finally got to installing the Jantzen superior Z caps on the crossovers.
The caps are quite a bit bigger than the standard Z's, but I managed.
You can see I had to turn the Erse coil on it's side...
/forum/index.php?t=getfile&id=2369&private=0
Previous Topic: Good Vibrations
Next Topic: Planar magnetic headphones
Current Time: Mon Nov 23 01:01:40 CST 2026
