Home » Audio » Pro Sound » DAW less complicated than Reaper?
Re: DAW less complicated than Reaper? [message #90217 is a reply to message #90188] Thu, 02 May 2019 17:45 Go to previous message
I believe Apple considers GarageBand to be the lite version of Logic Pro X. Both have the same UI in the beginning and GarageBand files seamlessly convert into Logic files. It still isn't the same as offering a free trial in my opinion because you can't test all the loops or all the audio plug-ins. You can't play around with the MIDI collection or the sample-manipulating synthesizer. Those features, and how they work, are make or break to some artists. GarageBand is still a great DAW, you just don't get as many options.
Previous Topic: Digital Editing
Next Topic: Digital piano
Current Time: Fri Oct 30 08:26:00 CDT 2026
