Home » Audio » Speaker » Passive radiator flanking sub/woofer.
Passive radiator flanking sub/woofer. [message #90143] Tue, 23 April 2019 13:56 Go to previous message
jonone is currently offline  jonone
Hi haven't been on the forum for a while....
This is a question kind of for Wayne if you don't mind answering. But anyone is free to give the opinion.
At the moment I'm using a 2 way speaker with stereo subs below and overlapping the crossover up to 150hz.
Not a true flanking sub approach as the room doesn't allow for the subs to be placed away from directly below the speakers.
I do have the subs turned 180degress so there facing the rear walls to act like a woofer in a different place.
My question is.
Do you recommend subs with passive radiators or is it best to stick to sealed subs? ( or ported)
Also my second question is, if a flanking sub has its driver facing forward but a passive radiator facing the rear wall will this act the same as facing a normal driver towards a wall and help the transitional area if crossed high enough? Acting like having a woofer in a different space.
Thanks in advance for the help.
Hope your well.
Jon
Previous Topic: Google Home
Next Topic: Echo Link, Echo Link Amp
Current Time: Thu Nov 05 02:27:38 CST 2026
