Wayne Parham Messages: 19107 Registered: January 2001
Just keep them in their sleeves and stand them up on edge in a temperature and humidity controlled environment and you're good. By "controlled environment," I just mean indoors at a comfortable temperature rather than in the attic or storage shed.
As for display, if you have very few, you could display each like a photograph, just as long as they are standing on their edges and inside their sleeves. The vertical orientation helps protect the grooves from crushing, warping and other mechanical damage. The sleeves protect them from dust.
I think most people store them like books on a shelf though. This allows a lot of records to be stored in a relatively small space. Don't pack them too tightly though, or it's not much better than a horizontal stack. The whole reason we don't store them horizontally is the weight of the records will compress the vinyl on the bottom of the stack. So by the same token, pack them loosely when putting them on the shelf so there is no crushing force.
