Home » Audio » Pro Sound » Is the difference in sound quality all in our head?
Re: Is the difference in sound quality all in our head? [message #89516 is a reply to message #89509] Mon, 07 January 2019 14:43 Go to previous messageGo to previous message
Hi, IMO the author of the article has 6 transistor radio ears. I agree that many things do not seem to matter, but equally many do. My personal experience has been that coupling capacitors do have a significant sonic signature and will alter the sound. Absolute polarity does as well. My system allows for easy swapping polarity (most don't). The polarity is sometimes difficult to determine with many recordings. With well done stereo recordings that have a singer in the center it will often show up as to whether the singer is in front or behind a line drawn between the speakers. Correct phasing will normally put the singer in front and supporting musicians slightly to the rear or in line with the speakers. This does require that the system is set up well and has flat response in that frequency range. Unfortunately again not all recording studios are consistent in the phase and worse some try to make it zero. In that case you lose a lot of the ambience and depth of the original presentation. With ear phones the issue is not really significant as few (except special ones that cover the whole ear and have multiple drivers) can distinguish the difference.
Previous Topic: Piano Applications on the Phone
Next Topic: Earphone Recommendations?
Current Time: Fri Nov 27 08:25:42 CST 2026
