Home » Audio » Source » Hissing while listening to vinyl.
Re: Hissing while listening to vinyl. [message #89441 is a reply to message #89427] Sun, 23 December 2018 15:26 Go to previous messageGo to previous message
Hi, Most likely what you are hearing is sibilance. It can occur because of a badly manufactured LP, but more likely is caused by the cartridge/stylus. Even with the best turntables some is possible. Anyhow, it is usually an indication of miss tracking. There are several ways this can occur. The most common are: insufficient tracking force, incorrect anti skating force, cartridge not aligned correctly, worn or damaged stylus (needle). You need to check any of those things you can. What brand/model of turntable do you have? What cartridge are you using?
Previous Topic: Shure no longer making cartridges
Next Topic: What explains new popularity of vinyl records?
Current Time: Sun Nov 22 23:48:45 CST 2026
