Home » Audio » Source » Stylus Inspection
Re: Stylus Inspection [message #89380 is a reply to message #89351] Sun, 16 December 2018 20:46 Go to previous messageGo to previous message
Hi Wayne, I use a stylus scope...actually they are designed for other things but work great for this. Many of the ones that might seem to be useful for this are really glorified toys. I went through three until I found one that really did the job right. I would have to look up the brand though as it isn't marked on it. Additionally, you will need a stable and accurate stand for it. Most that come with the low cost scopes are pretty wonky. Observation is not quite as easy as it seems as the thing you are looking at is quite small and in a location that often makes high magnification difficult. Lighting is key as well. I find that an external light source from the side is often more useful than the lights in the scopes. Send photos when you get some.
Previous Topic: Garrott Brothers Cartridge
Next Topic: Going physical in digital era
Current Time: Wed Oct 21 07:40:38 CDT 2026
