Home » Sponsored » Pi Speakers » Amp for 4pi speakers (Integrated stereo amp without dsp or AVR with audyssey)
Re: Amp for 4pi speakers [message #89287 is a reply to message #89286] Tue, 27 November 2018 13:51 Go to previous messageGo to previous message
Hi Wayne
Thank you for your quick and helpful answer!
You're right about the notch at 120hz. I always like to smooth the measurements a bit because it gives a good feeling. Embarassed Very Happy
A less smoothed image of the measurement from listening position without EQ shows clearly what you predicted:
/forum/index.php?t=getfile&id=2272&private=0
So, generally this notches would disappear with flanking subs for the upper midbass and lower midrange whereas more distant multisubs can smooth out below 100hz?
So... Adding 4 subs. Rolling Eyes Very Happy
Do these subs have to be big and is the position of the distant subs crucial?
The Audyssey EQ flattens/lowers the frequencies from 100hz to 300hz (which caused somewhat a muddy bass IMHO). This lowered frequencies already made a much better image in de midrange bass.
Can flanking subs/distant subs solve this acoustic problem around 200hz too or is EQ here the only cure?
Thank you, honestly.
Previous Topic: 4pi build and questions
Next Topic: 7Pi Build 2014
Current Time: Tue Oct 20 17:56:59 CDT 2026
