Home » Audio » Speaker » Length of Speaker Wiring (Will it affect the sound quality?)
Re: Length of Speaker Wiring [message #89193 is a reply to message #89178] Tue, 13 November 2018 09:52 Go to previous messageGo to previous message
No need to estimate - You can calculate:
Wire gauge - Resistance per 100 feet (both conductors, e.g. 200 feet total path length)
24 - 5.134
22 - 3.228
20 - 2.030
18 - 1.277
16 - 0.803
14 - 0.505
12 - 0.318
10 - 0.200
For best results, do not exceed 10% of the load impedance. So if the speakers are 8Ω, then choose a speaker cable that's around 0.8Ω or less. Speaker wire that's 100 feet long would need to be 16 gauge or larger to meet this goal.
For acceptable results, you can double the cable resistance to 20%. That increases insertion loss to 17% which is approximately 1dB.
Previous Topic: Speaker Lifespan
Next Topic: Small But Loud
Current Time: Sat Oct 24 11:21:33 CDT 2026
