Home » Audio » Craftsmen » Exposing The Wires Without Cutting It
Re: Exposing The Wires Without Cutting It [message #89192 is a reply to message #89190] Tue, 13 November 2018 09:20 Go to previous messageGo to previous message
You can use wire strippers, or you can carefully use a razor blade to cut through the insulation. With a lot of practice, you may find that you can use wire cutters, with the jaws held just close enough to cut through the insulation without nicking the conductor.
Previous Topic: Electronics For Dummies
Next Topic: Getting Started
Current Time: Fri Oct 02 04:44:04 CDT 2026
