Home » Audio » Thermionic Emissions » amp input stage
some test results... [message #8909 is a reply to message #8885] Sun, 17 April 2005 07:39 Go to previous messageGo to previous message
Hey-Hey!!!,
I removed the 150k grid leak resistors from the input stage of my amp and replaced them with 15k. The 20 cps output Z of my linestage is dictated by its 7.5 uF coupling cap, so a 15:1 ratio of input Z to linestage output Z seemed OK from a filter/freq response POV.
I find the system a bit cleaner now. It's not a big difference, but subtle ones are OK with me at this point. Same type of resistor, a 1/2 watt carbon film from Radio Shack.
After listening for a while, I keep thinking that the change was worth it. A worthwhile deviation from std. practice if a system analysis looks to support the change. I would not suggest trying this if a Dynaco PAS 3 were the linestage. A 12AX7 and .22 uF or so coupling cap is not going to cut it I suspect...
regards,
Douglas
Previous Topic: Cathode drive
Next Topic: November 2005 Vacuum Tube Valley Southern California Audio Festival
Current Time: Sun Nov 29 18:09:20 CST 2026
