Home » Audio » Home Theater » Large Screen TV or Projector (Which is better for Home Theater?)
Re: Large Screen TV or Projector [message #88951 is a reply to message #88948] Sun, 07 October 2018 12:06 Go to previous messageGo to previous message
There is one big advantage when using a projector - You can place the center channel speaker behind the screen. That allows a good quality loudspeaker to be used.
Most center channel speakers that are designed to mount below a television are terrible. You really can't make a good loudspeaker that's short and wide. The typical design uses horizontally arrayed drivers, which then create lobes and nulls in the listening area. I'd rather have a phantom center than that.
Previous Topic: Location Setting For Sound Quality
Next Topic: Lifespan of Plasma TV?
Current Time: Thu Nov 12 05:58:26 CST 2026
