Home » Audio » Room Acoustics » The shape of the room
Re: The shape of the room [message #88947 is a reply to message #88932] Sat, 06 October 2018 04:57 Go to previous message
Wayne Parham wrote on Wed, 03 October 2018 13:03
The ideal room is outdoors, because there are no walls or ceiling to act as reflectors. Obviously, that's not an option so next best thing would be a very large, well-damped room having randomly contoured walls with no large flat surfaces. That's probably not an option either so the next best thing that's reasonable is a room that is well-damped and has no dimensions that are integral ratios of another.
Most times, you have to work with what you have. But damping and multisubs really help smooth room modes. If I had to choose between a golden-ratio room with hard surfaces and a single subwoofer or a square room with panel dampers and multisubs, I'd choose the latter. So you can work with a square room or one with 2:1 dimensions if that's what you've got.
What I have gathered from this is that you can work with whatever space you have and make the best out of it by making the necessary adjustments. I guess outdoor spaces work well because there are no echoes and sound reflections.
Previous Topic: Easy way to stop an echo in a large room?
Next Topic: The size of the room
Current Time: Thu Sep 24 19:31:12 CDT 2026
