Home » Sponsored » Pi Speakers » Sound for small gym (Sound for small gym)
Re: Sound for small gym [message #88919 is a reply to message #88906] Sun, 30 September 2018 21:42 Go to previous messageGo to previous message
Room modes are less a problem in large rooms. The bigger problem in gymnasiums is the hard, reflective surfaces on all sides. It makes a midrange reflection problem, and a lot of echo. The directivity of the speakers will help, and that's sometimes as much as you can do. But you might also pad the walls, if possible. Gymnasiums often have padding for safety reasons, and it serves double-duty as sound damping material. It isn't much, but it helps.
Previous Topic: 7pi vs 8pi
Next Topic: 3Pi Subwoofer Weight
Current Time: Tue Nov 03 02:44:07 CST 2026
