Home » Audio » Craftsmen » Cabinet for subwoofer.. bad idea?
Re: Cabinet for subwoofer.. bad idea? [message #88898 is a reply to message #88895] Thu, 27 September 2018 13:00 Go to previous messageGo to previous message
What I'm saying is don't mount a woofer in a cabinet without knowing that the two work well together. The cabinet and woofer are a tuned system, and one affects the other. You can definitely mismatch them.
Subwoofers are pretty simple devices. So they're probably the easiest speaker system to get right. But you can get them wrong too. Just make sure.
If you don't know what to do to "match" the woofer with the box, search this forum.
Previous Topic: The Last Thing You Fixed
Next Topic: Type of Wood
Current Time: Fri Oct 30 06:06:56 CDT 2026
