Home » Audio » Craftsmen » The Last Thing You Fixed
Re: The Last Thing You Fixed [message #88804 is a reply to message #88689] Sun, 09 September 2018 11:11 Go to previous message
Just fixed my dad gum lcd tv. With the aid of You Tube, which can come in handy at times. The volume would go down or up all by itself and the ir light would blink incessantly. The u-tube and a fix it forum said to remove the side manual button's connector. So far so good. Also, I've helped a friend keep his old Mazda truck going down the road. Once again, u-tube. After a brake line failure, when he got it back the rear wheels would lock up. Turned out the fluid reservoir was filled up too full over the fill line. Something simple and cheap fixed it. Taking it to a shop would have entailed multiple parts and bills to do what some paper towels sopped up.
Previous Topic: Projects for Beginners
Next Topic: Cabinet for subwoofer.. bad idea?
Current Time: Fri Oct 30 07:15:27 CDT 2026
