Home » Audio » Home Theater » Furniture influence on sound
Re: Furniture influence on sound [message #88666 is a reply to message #88664] Fri, 10 August 2018 15:49 Go to previous message
JazzHog is currently offline  JazzHog
Floyd wrote on Fri, 10 August 2018 13:45
I don't think the cats interfere with the sound quality - except when the younger one tries to chew through the cables.
Have you thought about covering your cables? You can buy some tubular plastic that can be fitted round cables, and this stops pets from chewing them. It is also good for keeping cables together if they are going in the same direction, rather than having them separate.
Previous Topic: Hiding The Cables
Next Topic: Window Panes Breaking With Loud Sounds
Current Time: Fri Nov 13 06:50:10 CST 2026
