Home » Audio » General » Does The Weather Affect The Quality Of Music?
Re: Does The Weather Affect The Quality Of Music? [message #88638 is a reply to message #88622] Thu, 09 August 2018 17:22 Go to previous messageGo to previous message
Hi, A qualified maybe. There was some information on this a long while back by the reviewers at Stereophile. When they tested stuff in the main office area in Santa Fe (8000 foot level) it was different from when tested at lower elevations. They noted also that high humidity and temperature tended to change results. This almost exclusively applies to speakers. Since then I suspect that most newer speakers are treated to avoid such issues. Temperature can still affect mechanical systems though. My direct drive turntable seems to change speed slightly based on temperature. When cold it actually runs a bit fast (about 1-2%) and requires the trim to be adjusted.
Previous Topic: An Old Telephone From.........The '50s Maybe?
Next Topic: Innovations that changed media consumption
Current Time: Wed Sep 23 03:14:23 CDT 2026
