Home » Audio » Thermionic Emissions » 300b vs 2A3
Re: 300b vs 2A3 [message #8842 is a reply to message #8841] Fri, 04 March 2005 20:47 Go to previous messageGo to previous message
Poindexter is currently offline  Poindexter
It is not an adversary relationship.  The major difference in implementation is that a 300B will give you about three times the amount of max (practical, what-have-you) power out.
If I would characterize the 'sounds' of the devices according to my experience:
300B; romantic, lush. If a fault, histrionic.
2A3; clear, clean, tight. If a fault, dry.
But; it all depends. On the amp, the pre, the source, the speaks.
You said you have FE168Sigmas. Which ones; the new ones with the Escherian/Fullerian cone/surround/cap, or the older model with the exponential cone and whiz?
Poinz
Previous Topic: Continental Capacitor type A oil capacitor info wanted?
Next Topic: Schematic for Heath AA-11?
Current Time: Sat Sep 19 06:11:07 CDT 2026
