Home » Sponsored » Pi Speakers » Four Pi crossover adaptable to 16R JBL 2226? (Can the PCB Xover hold components for 16R woofer?)
Re: Four Pi crossover adaptable to 16R JBL 2226? [message #88269 is a reply to message #88260] Fri, 29 June 2018 09:57 Go to previous message
The crossover is designed for the 2226H. You might be able to scale the woofer circuit parts to use the 2226J, but I haven't tested it. Might need some fine-tuning. And don't forget the voltage sensitivity shift - You'll need to change the tweeter attenuation to compensate.
Previous Topic: 7Pi thoughts and questions
Next Topic: Eminence H290B vs. H290C vs H290S
Current Time: Thu Nov 26 12:12:21 CST 2026
