Home » Audio » Source » Turntable Drawer
Re: Turntable Drawer [message #88235 is a reply to message #88232] Fri, 22 June 2018 16:55 Go to previous messageGo to previous message
Hi, I suppose there is one somewhere out there. My thought is that I would not use it though. Two basic reasons, first is stability. It would be likely to vibrate whenever you crank up the music and cause feedback. Second is that turntables work best when level. Even a few degrees off level will tend to cause problems for high quality turntables. If you are serious about music then I would opt for a shelf with a cover. It can be made far sturdier and the sound vibrations will be less likely to cause problems and the turntable will function better on a level stable shelf. On the other hand if you are not so serious about it all , then just go get some drawer glides from some place like Home Depot and build something that suits you needs.
Previous Topic: Why do you buy CDs?
Next Topic: What would you do with a load of old 78's?
Current Time: Mon Nov 16 10:15:06 CST 2026
