Home » Sponsored » Pi Speakers » 4Pi Rough concept
Re: 4Pi Rough concept [message #88103 is a reply to message #88102] Sat, 02 June 2018 21:39 Go to previous messageGo to previous message
Josh,
Yes, it is one of the ranches. Interior wise, we don't have a set style so I don't have to match any specific style.
That is a jointer that is hiding in the corner. Have to move a couple bikes to use it. I have two car garage's worth of tools in jammed into a one car garage.
Decided to cut the depth down to designed depth of 14.5" They look much better.
I glued and screwed the sides. They will be covered by something so not worried about looks. Trying for the most strength as I envision them being moved a lot. Back is loosely placed in to keep them square while glue dries.
index.php?t=getfile&id=2131&private=0
Got the cleats in and screws for back set.
index.php?t=getfile&id=2132&private=0
  • Attachment: back.jpg
    (Size: 57.93KB, Downloaded 583 times)
  • Attachment: sides.jpg
    (Size: 70.24KB, Downloaded 2908 times)
  • Attachment: bluetooth.jpg
    (Size: 73.73KB, Downloaded 2946 times)
Previous Topic: 7Pi Plans request
Next Topic: 3pi crossover
Current Time: Tue Oct 20 08:58:43 CDT 2026
